HP Monitor LED
This topic has been moved from the section Networking to section Computer Peripherals by Grumpy9117
depends. what is your serial number, product number, and model number? the product and serial numbers will be found on the back, and the model number will be on the front on the bottom right. and also when did you buy this monitor?
unless the particular monitor comes with a special custom cable (like some old crt monitors did) then it uses a standard cable. this is probably either a dvi, vga or hdmi connection on one end and whatever your pc outputs on the other.
all you need to know are what ports you need to connect up.
