HP Officejet 7500A not compatible with Win XP Pro 64-bit?
2random
I just purchased this great new Wide Format All-In-One printer and failed to read the fine print that DID NOT list Windows XP Pro 64-bit among the supported operating systems. Apparently all other operating systems 32-bit or 64-bit are supported, just not XP 64-bit. I really don't want to return the printer or have to upgrade both my desktop and laptop computers which are both functioning perfectly on Win Xp 64-bit.
I contacted HP and they basically told me that I was SOL. Any other solutions or work-arounds out there? The disk won't let me even install the software, it simply says my os is not compatible.
finally after 1 hour i've solved the problem.
i've gone to printer and fax (i don't know the right name i have windows xp 64 in italian language)
then i've add manually a printer.
i've selected "printer connected to the pc"
i've create a new tcp/ip port and give the ip that has the printer (now the printer ip is manual not with dhcp)
then printer install but not work.
after i've gone
http://support.apple.com/kb/DL999?viewlocale=it_IT&locale=it_IT
to download the bonjour print service
and finally install bonjour
it found the printer and install it.
how my HP Officejet 7500A - E910a works in wifi under Windows XP 64bit SP2.
hope this will hwlp you...
see you...
Tony's help was great. I could print with my 7500A in wifi terms, but, culd you scan from it to pc??
I see in this way we just install the printer driver, but there's not "HP" folder or app after installation... 🙁
Did somebody? did you, tony? can you help me? thank you!
