I have an old printer that will work if I fill it all the way with paper and use thick paper. But otherwise, it will lead to a "paper jam". Not really a paper jam but the paper stays back and the carriage makes an ugly noise and can be heard spinning. Is there one or two parts I might try to replace to tighten this or is there a control that I can tighten to get it to grab the paper better? Perhaps there is some part that wears over time. I would like to fix my printers. I keep buying and buying and they break so I would like to maintain them.
Like are there springs or rubber pads on the cylinder that can be replace and/or adjusted? Or some other mechanical sensor or spring? And can any of this be diagnosed and measured on my PC somehow while the printer is in maintenance screen. There is a maintenance list.
