HP OmniBook XE3 slows down to half speed even when plugged..
G
Guest
Guest
Archived from groups: comp.sys.hp.hardware (More info?)
My HP OmniBook XE3 regularly decides to slow down to half speed (from
1 GHz to about 470 Mhz, sometimes to around 730 MHz). I can imagine it
doing that when it's on battery, but when it is plugged in I want it
to actually use it's full 1 GHz. In fact, I would like to be able to
tell it that it shouldn't even slow down when on battery. Is this some
configuration-item on the HP? Where can I find it? Please help me out.
Thank you very much
Eristalis Pertinax
On the seventh day, Eristalis Pertinax wrote...
check your Power option settings in the control panel. Set it to desktop
and change the options for running under battery accordingly. Or use
SpeedswitchXP or the intel SpeedStep applet.
mit freundlichen Grüßen/with kind regards
Christian Dürrhauer, Institute of Geography, FU Berlin
Does anyone REALLY read these stupid quotes?
