Hp pavilion G6 black screen wireless light orange fan runs no hdd was running a little hot before it shut itself down now blac
sukie54
4
i was using it and it was ok went out of room came back and it had switched itself off now black screen please what can it be
I'm having the same problem but my light over the number pad and the light by the caps lock keeps blinking nonstop. I tried the options stated above but it only worked once. It's black again. Don't know what else to do...I have a lot of work saved that I need to finish...Help please 🙂
I have tried all the suggestions and still nothing. The only thing I can suggest is to get a cheap one off eBay and swap the hard drive over so you can access your work then sell your old one as spares to cover cost of replacement. Apparently Hp are beggars for doing this
