HP pavilion g7 battery not working
The battery may have reached the end of it's life (ie can no longer hold a charge), in which case replacement new battery is required.
I can only recommend you buy a new battery from HP to ensure compatibility and safety.
You can buy cheaper ones from various online suppliers but they can have various issues like getting too hot, not being totally compatible with your laptop, or dying after only a few months. You may get lucky but is it worth taking that risk? I think not.
