Hi,
All most batteries should have either 10.8V (11.1V) or 14.4V (14.8V) on the label. WHr divided by amperage is Volt. for example, 48whr / 4.4A (4400mah) is roughly 10.8V.
However, In my maintenance manual,
Operating voltage:
18.5 V dc @ 3.5 A – 65 W [65W÷3.5A=18.5 Volts]
19 V dc @ 4.74 A – 90 W [90W÷4.74 A=18.987 Volts]
18.5 V dc @ 6.5 A – 120 W [120W÷6.5 A=18.46 Volts]
Also, on the battery cabinet, only 18.5 V ___ 6.5 A is written.
Also, In my HP maintenance manual, only the 6-cell, and 9-cell batteries are mentioned.
Description-------------------------------------------------------------Spare part number
9-cell, 100-Whr, 3.00-Ah Li-ion battery---------------------------- 636631-001
6-cell, 62-Whr, 2.80-Ah Li-ion battery------------------------------ 593562-001
6-cell, 55-Whr, 2.55-Ah Li-ion battery------------------------------ 593554-00
I found a 12-cell battery(Capacity: 9600mAh, and Voltage:10.8V)Compatible For HP
So, As a result, my questions are:
(1) You think this a 12-cell battery with (Capacity: 9600mAh, and Voltage:10.8V) can be compatible with my HP notebook battery voltage?
(2). The 6-cell battery is with a spare part number(593554-00, or , 593562-001) and the 9-cell with another different spare(636631-001). However, I found a 12-cell battery in eBay with the same 636631-001. You think a 6-cell battery, 9-cell battery, 12-cell battery can be found with same spare part number, as 636631-001 which is compatible for a notebook battery, although their description(-6-cell, 9-cell, 12-cell) are different each other.
(3). You think 12-cell battery will last more than 9-cell battery, much more than 6-cell battery? However, I heard that 9-cell or 12-cell batteries would heighten the notebook from the back.
Operating voltage:
