So my Grandma gave me her HP Pavilion P6620f to fix. She said it would freeze and then go through a cycle of shutting down and turning back on.
She gave it to a guy to fix before me who said there were bad chips near the video portion of the board, so he put in a GPU. He said the PSU that was in there wasn't the one that was supposed to be, so he replaced it as well. He also put in a new Hard Drive and wrote Windows 7 back on, setting it up with the restore Discs that came with the Computer when it was originally purchased.
I got it out here and it turned on just fine. I left it on overnight and it didn't malfunction. Left in on while I was at work and it worked fine when I got back. I woke up today and the screen was Display was blank. After 32 hours, it had finally froze.
I held in the Power button to shut it down, but when I pressed it again, the PC would boot, but there's nothing on the display. I manually shut it down again and back on, same thing. I did this 3 times, then unplugged everything for a little while. Plugged them all back in and I got the splash screen for the motherboard, then it went to a black screen with a blinking line. I shut it down manually, turned it back on and now I'm back to no Display.
Any ideas on what could be causing this?
*Update" I disconnected the PSU from the motherboard, reconnected it and the PC turned on normally. After about a minute, it went to the BSOD mentioning a faulty driver trying to corrupt the system. "Stop: 0x000000C4 (0x0000000000000091, 0x0000000000000002, 0xFFFFF88002F1FFC0," there were other codes there, but they didn't fit in the picture, I think it was just 0x0's the rest of the way.
I turned it off, turned it back on and back to no display. I removed the PSU again, and it turned on just fine. Then when I went to pull up Firefox, the PC restarted. It then went through the whole boot sequence, but when it got to the "Welcome" screen, it froze and this long beep started. I turned it off, turned it back on and it froze at the splash screen. Shut it down, turned it back on to boot into safemode, it ran fine for a few minutes, restarted and I got the blinking line again.
