I was doing repairs to my HP PAVILION P7-1142 and somehow misplaced my notes on where the front panel USB / SD-Media cables go - USB1, USB2, etc.. I was able to figure out the Audio and Front panel power / LED headers, but the USB ones have strange headers with more pins than the cable plugs. So I need information on where each cable goes and the orientation of the plug like, say, ‘end of plug with red wire goes to pin one’ --- (especially for the single row 4 pin plug with a filled 5th pin)
Normally it is no problem as the USB plugs and headers are keyed to match, but in this case – no such luck.
I am attaching a link to photos of my cable-ends and headers. Apparently, the P7-1154 has a similar configuration. So anyone with info on the P7-1142 or P7-1154 should be able to help me ( if I'm not mistaken): https://1drv.ms/f/s!Ah4hgvy8W5LIizsCm-I7VYE92XGv
Thanks ahead of time for any help!
