First of all, I have read the product reviews on this website for a while, but for some reason I never bothered with the forum. Since this is my first post, constructive criticism is welcome. Thanks!
PC Specs
Motherboard Specs
Modifications:
Exactly one week ago at the time of this post I turned on my computer as normal. The light came on, the dvd drive spun a few times, and nothing happened. After trying all of the display outputs, I took the pc to my workbench and, upon further inspection, discovered that a capacitor had broken. I sent off for a new motherboard and received it today. I installed it without any problems and started the pc. The same thing happened with one difference: the cpu fan became unbearably loud. After trying all of the display outputs again I unplugged the pc again and did everything this thread said to do and also reset the CMOS battery & checked all of the wiring. Finally, I reseated the CPU, which quieted the fan but did little else. Thus my question to you, good people of this forum, is what should I do next to solve this problem?
PC Specs
Motherboard Specs
Modifications:
4GB DDR2-800 RAM
AMD Radeon HD-5450 (mfg. MSI)
