Hp pavilion weird fan noise
4
Bought hp pavilion 17 g084ca and everything is fine except the weird noise coming from the right corner of the laptop sounds like whirring. And it's not on the fans side and it's annoying me
Hi,
I would like to suggest to open the laptop and check if there's anything hitting the fans inside it but since it's still covered by the factory warranty it's best for HP support to check themselves. The whirring sound can also either be the HDD startup or there's a disc inside the DVD try that is being read. Try to pin point first where the sound is really coming from and contact HP support right away.
