D dhenrichon Distinguished Dec 24, 2011 3 0 18,510 Dec 24, 2011 #1 Hello, On HP XW4600 need a 550W do you know a compatible power supplies Thank you
Solution O O o1die Dec 24, 2011 Two good brands for your hp, corsair and antec: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027 http://www.newegg.com/Product/Product.aspx?Item=N82E16817371044
O o1die Illustrious May 16, 2001 14,175 0 42,960 Dec 24, 2011 Solution #2 Two good brands for your hp, corsair and antec: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027 http://www.newegg.com/Product/Product.aspx?Item=N82E16817371044 Upvote 0 Downvote Solution
D dhenrichon Distinguished Dec 24, 2011 3 0 18,510 Dec 25, 2011 #3 o1die : Two good brands for your hp, corsair and antec: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027 http://www.newegg.com/Product/Product.aspx?Item=N82E16817371044 Thank you so much, I appreciate the time you spend for this Thank you Denis Upvote 0 Downvote
B bwf1975 Distinguished Apr 15, 2008 144 0 18,710 Dec 25, 2011 #4 cant go wrong with them makes, they all good Upvote 0 Downvote
D dhenrichon Distinguished Dec 24, 2011 3 0 18,510 Jan 5, 2012 #5 Best answer selected by dhenrichon. Upvote 0 Downvote
