HP Printer network printing problem
cyberdigr
Model: HP LaserJet P3005dn I'm using Mac OSX (Snow Leopard)
The machine will print out configuration when using the menu display buttons but documents sent to it will not. LAN is enabled. I open Bonjour and the printer is visible however when I double click it (select for more info) the link does not respond. The network port in back has a solid green light and a flashing orange/yellow light. I'm assuming that indicates a network problem.
In older models, I could switch the network card and/or switch the network card port and that often corrected the problem. However, this new model has the network card built directly as part of the format board. Any troubleshooting advice?
1st thing to do - get a crossover cable and connect the printer directly to the computer to rule out any cabling/switch/router issues. I would also try a different computer, preferably a windows PC. If that fails then yes there could be a problem with the printer requiring replacement of the formatter board.
