[SOLVED] HP pro 3330 mt cpu upgrade
TheeCatalyst21
73
5
10,545
I'm planing on upgrading this old office pc for gaming, not for online just Skyrim & Fallout 4.
Now it has a intel pentium g630, I've check for compatibly for the Intel H61 chipset. There are good I5 & I7's
http://www.cpu-upgrade.com/mb-Intel_(chipsets)/H61_Express.html
And what other user have on the same unit, https://www.userbenchmark.com/System/HP-Pro-3330-MT/4201
But I want to know if I can use intel xeon processors for LGA 1155, like the Intel xeon e3-1230 v2.
https://ark.intel.com/content/www/u...n-processor-e3-1230-v2-8m-cache-3-30-ghz.html
You're probably going to be limited to an i7-2600/3770
The best advice is to use a CPU that was available in one of the configurations of a particular OEM machine at the time.
