hasd15568 :
hang-the-9 :
Check for a newer BIOS, and plug it in. It should work. If not, put the original one back.
i found bios update but for win 8
i dont know if work on win 10
That is a utility to run the BIOS setup, you can try to run it, if it runs, will work.
