HP pro 3500 mt upgrade cpu
hasd15568
108
I bought i5 3470 for my sec pc hp pro 3500 i read so much about if i want to upgrade cpu i will need update bios
The question is if i install cpu now will it work without bios update ??
My bios ver : 8.11
i need short answer
If the bios update require what ver i should update to
Thanks
Yes i figured there was a chance it would as i said. The system was available with that CPU originally. Glad it works.
That system was available with the i5-3470 so in theory it should just work. However if youve searched HP forums and people are telling you it needs a BIOS update it needs to be done BEFORE installing the CPU. Put the latest one in 8.14
https://support.hp.com/us-en/drivers/selfservice/hp-pro-3500-microtower-pc/5270849
thanks i try install this cpu without install any bios updates and this shocked me
RUN without anything just install and play
thank you very much
i search for days for update this bios and everyone say update the bios
and finally this worked
i dont know how to thank you man
