hp probook light blinking problem
Lamia_
Commendable
Oct 18, 2016
My battery drained out and I plugged in my adapter. The white light is blinking continuously. I can't switch my pc on. In regular times, when I plug the charger in, there is an orange light. Holding the power button removing the battery procedure ain't working here. Please help asap. Exam's tomorrow. Thanks in advance.
Try the following and see if it will turn on.
1. First make sure the device has been charged.
2. Unplug your charger cord.
3. Remove the battery.
4. Press and hold the "Power" button for 30 seconds and see if the device will turn on.
5. If it does, great, if not yet, no big deal. Now plug back in the power/charger cord. (If it didn't turn on without the cord in, it should turn on once you it is in. Yes sometimes they will turn on, or try to turn on, even with nothing attached/plugged in.)
6. Now put the battery back in.
If this doesn't help, then test the power cord to see if it is good. Either try your cord in another device, or try another devices cord in your laptop.
Should that not be the problem, then check the battery to see if...
Should that not be the problem, then check the battery to see if it needs replacing.
