G
Guest
Guest
I have an HP scanner, and when scanning a document in, it allows you to pick the size of the saved image (i usually save in jpeg format). That's all fine and dandy until it saves it to an image file that is over 4 times larger than the standard 8.5 x 11 paper. I have the newest version of software from the HP website. Anyone have any similar problems?
