HP sued for deceiving ink printer users (San Jose Mercury ..
G
Guest
Guest
Archived from groups: comp.periphs.printers,rec.photo.digital (More info?)
A class action law suit was filed in Santa Clara County superior
court. It alleges that HP's 'smart printer' technology deceives
customers to buy new ink cartridges before the ink has run out.
The software renders cartridge unusable through the use of built-in
expiration date.
So far the allegation, neither party was willing to comment on
this litigation. The class action is on behalf of users who bought
HP inkjet after February 2001.
However, in this article San Jose Mercury quotes an ink printer
test published by PC World in March 2004 edition. PCWorld found
out that many printers stopped to print before the ink runs out.
For example, Epson Stylus C84 stopped with 20% of the ink left,
and Canon i850 stopped with 10% of the ink left.
If all this is truth, they just found the best possible source
of income...
Thomas
I believe most of us assume that virtually all the ink in the cartridge
is there to be used. This really bothers me because I only use my HP
printer for final prints, thereby raising the question in my mind if I
am being ripped off. I have looked at my documentation and can find no
evidence of what to expect. Nor does my printer, purchased two years
ago, give me any heads up on remaining ink.
This mess is one reason I like Canon printers with individual
transparent easily refillable cartridges. What you see is what you
get.
There's no secret that inflated ink prices are what drives HP's market
share. Nor is there any secret that were this to change HP would see
its profits and prospects head in the direction not only of its low
margin pc business (and deteriorating server one), but Dell. And guess
what. This will happen.
>expiration date.
>of income...
I can tell you for a fact that HP is not
alone in using such technology.
rafe b.
http://www.terrapinphoto.com
"ThomasH" <henrymot@coco.net> wrote in message
news:421C3C38.C2EA68CB@comcast.net...
> of income...
> Thomas
If you are talking about trial lawyers, maybe. The lawyers will get paid
millions of dollars. The consumers they are supposedly protecting will get a
coupon for ten bucks off on an HP printer.
Once with an Epson printer I tried an experiment, printing as many
sheets as I could after the "low ink warning", until the photo was
obviously off-color, indicating one of the inks had indeed ran totally
dry. I got another 10 or so photos, IIRC. *But* when I put a new cart
in there was the mother of all air bubbles between the ink in the cart
and the printer head and it took maybe a dozen cleaning cycles and 30
minutes of futzing around to finally get the ink back to the head.
Last time I tried that experiment.
So I think the reason there's still some unused ink is to avoid getting
air pockets in the line. Anyone bothered by this should switch to the
CIS systems. What's important is the cost per sheet, not whether or
not there's some ink left in the tank when the warning light comes on,
I feel.
> expiration date.
> of income...
> Thomas
I have had 5 different HP inkjet printers, and NONE of them ever stopped
printing when the ink ran out. The ones I currently have in use warn
you that you may be running out of ink, but they do NOT stop printing,
even when the ink runs OUT. I suspect this is another of those totally
specious lawsuits based on nothing but desire to get into the pockets of
major companies who would rather pay than be tied up in court.
Ron Hunter rphunter@charter.net
Joseph Meehan wrote:
> I would think the issue is how did the represent what they were selling.
> For example if they indicated that it would use all the ink in the
> cartridge, then they have a problem
The basis of the complaint seems to be that they did not disclose the
fact that the cartridges would cease functioning after a specific date,
regardless of how much ink was left in them.
Bob
Same exact experience over here. I suspect
Epson's design only allows for or expects
about 70% "efficiency" out of the small carts.
Which is infuriating when you consider the
cost per milliliter of most inks.
> I feel.
Or stick with the "pro" printers that use
large and stationary carts (which almost
amounts to the same thing.) This was my
main reason for choosing the HP Designjet
as my "desktop" printer.
rafe b.
I'm glad to see that something is being done.
For those that may have missed it being discussed here in
rec.photo.digital I kept the following for future reference of how to
reset expiration dates.
My HP932c [purchased Nov.00] is not affected but my next printer would
be.
Google is your friend:
http://www.google.ca/search?hl=en&q=HP+resetter&meta=
.... try search strings like "Epson resetter" & "smart chip ink
cartridges" <no quotes> to find more.
Hap
---clip---
On Fri, 17 Sep 2004 18:11:10 GMT, "Christopher Muto"
<muto@worldnet.att.net> wrote:
why? the manufacturer would probably tell you that the dates are to
ensure a good experiance with their product through the use of fresh
cartridges. i would tell you that the dates are so that they can sell
you more cartridges. i think all the majors have implemented some sort
of scheme like this... the cartridges have a chip built into them that
can be reset if it is considered 'expired' or if you wanted to remove
and refill it. search the web for "hp resetter" (or for epson, "epson
reset tool") and you will find several... a manual way of reseting the
cartridge/printer to accept the expired or previously used cartridge
is listed at the link below. there are three methods and only one may
work on your particular model, but try them all with particular
attention to the third method suggested which is the easiest,
cheapest, and simplest, but may not apply to your model printer.
it may be more economical to purchase a non-hp cartridge than the
resetter tool and ink refills for a person that does not print very
often.
http://www.inktec-uk.co.uk/57_58_reset.htm
"Agent Orange" <agentorange@arboral-systems.com> wrote in message
news:ieplk053v0lv0qlm08j97eqatblq2hef2t@4ax.com...
> Q: What is the significance of the date printed on the HP ink PACKAGE?
> SINGAPORE MAY 2003
> > Relevant Hewlett Packard ink cartridge dates are:
> > - The date HP manufactured the ink cartridge
> > - The date HP prints on the ink cartridge
> > - The date HP prints on the ink cartridge package consumer cardboard box
> > - The date HP printer cartridges are installed in the printer
> > - The date HP first stops printing (due to false "low ink" messages)
> > - The date HP usually stops printing (due to false "expiration"
messages)
> > - The date HP actually stops printing (due to true expiration messages)
> Since we now know full well HP inserts up to three false expiration
> dates before the final (true) expiration date, I ask this question:
> Q: What is the MEANING of this date printed on the HP package box?
> SINGAPORE MAY 2003
> Note 1: Box-print-date is NOT the date the cardboard box was
> actually printed (as a quick look at packages on the
> store shelves shows most, if not all, to be in the future).
> Note 2: Box-print-date also can not be the Cartridge_print_date as
> the date printed on the HP ink cartridge is easily proven
> to be different simply by opening a box.
> Given that actual re-fill tests proved (in ascending order):
> a) derived_true_manufacture_date
> = 2001/12/10 (cartridge printed date - 2.5 years)
> b) date_cartridge_was_purchased
> === 2002/01/12 (date cartridge was purchased)
> c) date_cartridge_was_installed
> === 2002/01/14 (date cartridge was placed in service)
> d) date_hp_prints_on_the_ink_box
> = MAY 2003 (What is the significance of this date?)
> e) 1st_false_hp_empty_date
> ~= 2004/05/14 (approx. 800 pages of ink printing)
> f) 2nd_false_hp_expiration_date
> = 2004/06/10 (date actually printed on ink tank)
> g) 3rd_false_hp_expiration_date
> = 2004/07/14 (2.5 years of contiguous printer service)
> h) true_hp_ink_expiration_date
> = 2006/06/10 (cartridge printed date + 2 years)
> Q: What is the significance of the date HP prints on the
> outside PACKAGE of the cardboard box containing ink tanks?
>expiration date.
>of income...
>Thomas
The Deskjet and Designjet series inkjet printers will stop when they are
out. In fact the Designjet 750 will refuse to print if the some of the
nozzels are clogged. It will stop in the middle of a print and tell you
to service the cartridge.
This is an issue of cartridges that have time stamps in them and
printers that refuse to use them after they have expired, regardless of
ink content.
I read somewhere that HPs stand is the ink might go bad and they don't
want to risk consumers with bad prints due to expired ink.
Bob
> cartridge is there to be used.
However what is your expectation of the number of prints each cartridge
will produce? I believe, that while you may assume it will use all the ink,
what you really are looking at is the number of prints per cartridge.
For all I know it is not practical from an engineering point of view to
totally empty the cartridge. Maybe the delivery will become inconsistent or
maybe they can not measure accurately, so they provide more ink that the
cartridge is designed to deliver to assure a consistent result.
There is nothing the consumer hates more than inconsistent results. If
you get 100 prints on one cartridge and then only get 95 on the next
printing the exact same prints, you are going to be mad. I have often
visited manufacturing facilities. The quality control lines of the better
products often reject products that we would normally consider inferior like
not enough beef in the vegetable soup, but they also reject the cans with
too much beef. Beer lines reject bottles that are under-filled but they
also reject over-filled bottles.
> use my HP printer for final prints, thereby raising the question in
> my mind if I am being ripped off. I have looked at my documentation
> and can find no evidence of what to expect. Nor does my printer,
> purchased two years ago, give me any heads up on remaining ink.
> get.
> guess what. This will happen.
Joseph Meehan
26 + 6 = 1 It's Irish Math
I have a lexmark z605, which cartridges also cost an arm and a leg,and I
bought refills.It costs only 15 euro and has 2 20 ml syringes, also 4
refills.It has even gloves!It's made in Korea,BTW.
Tzortzakakis Dimitri?s
major in electrical engineering, freelance electrician
FH von Iraklion-Kreta, freiberuflicher Elektriker
dimtzort AT otenet DOT gr
? "ThomasH" <henrymot@coco.net> ?????? ??? ??????
> expiration date.
> of income...
> Thomas
Strange, all the HP printers I've used keep going until the ink runs out and
any warnings of low ink can be ignored.
> expiration date.
> of income...
> Thomas
The mechanism in the HP is somewhat different form the otehrs you
mention. Most permanent or semi-permanent inkjet printers leave some
ink in the cartridge when it reads empty to prevent either head damage
(in the case of the Canon, or air locks and head drying out internally
for the Epson.
However, some HP printers have a expiration date programmed into them,
so the printer simply stops when tat date is reached. It is apparently
shown on the box, and I believe HP will exchange cartridges if you have
new ones that are expired. Their claim is that their inks become
unstable in some manner after a certain date and can clog or damage the
printer in some manner.
Art
> expiration date.
> of income...
> Thomas
>> totally dry. I got another 10 or so photos, IIRC. *But* when I put
>> a new cart in there was the mother of all air bubbles between the
>> ink in the cart and the printer head and it took maybe a dozen
>> cleaning cycles and 30 minutes of futzing around to finally get the
>> ink back to the head. Last time I tried that experiment.
Your cost anyway. I suspect the cost to HP is much much less.
>> getting air pockets in the line. Anyone bothered by this should
>> switch to the CIS systems. What's important is the cost per sheet,
>> not whether or not there's some ink left in the tank when the
>> warning light comes on, I feel.
> rafe b.
Joseph Meehan
The HP carts I use have a marked capacity on them - 42 mL. This capacity is
also marked on the packaging.
It would be interesting to know if the system flags then as empty _before_
42mL of ink has been used? If it does then that sure sounds like there is a
case to answer.
If it prints all 42mL before flagging empty then there is no case to answer.
Any ink left in the cart is free.
Reuters had the story here...
http://today.reuters.com/news/newsArticle.aspx?type=technologyNews&storyID=2005-02-22T201958Z_01_N22550006_RTRIDST_0_TECH-TECH-HP-PRINTERS-DC.XML
Greg Coulter wrote:
> Regardless of the merit of this lawsuit, as an HP insider I can tell you
> with certainty one should stay at least 10 feet away from _any_ HP
> product produced in the last five years.
I'm rather impressed by the 4650 Color Laserjet. At least so far. And
the Laserjet 1000 seems to be great, too.
"bob" <not@not.not> wrote in message news:g85Td.29311$Rl5.18875@bignews4.bellsouth.net...
Did I mention they don't even make their own printers any more?
Why would that surprise us? Neither do
any of their competitors (Brand C, Brand E
and brand L.)
rafe b.
Most of the adverts for HP carts (eg @ Amazon) say things like "30mL useable
ink". Thats a very clear statement of what the cart can deliver.
As you say the issue is not how much ink is left in the cart but how much
you can get out (eg compared to the stated or advertised value). If the
packaging or advert says "30mL useable ink" but shuts off before that amount
has been used then it sounds like there is a case to answer. As long as 30mL
is useable it doesn't matter how much is left in the cart.
Gosh, The Inquirer had the story back in 2003, with more technical details:
http://www.theinquirer.net/?article=9220
>>of income...
>>Thomas
Quite right. The laws on class action suits REALLY need work.
> I feel.
Another factor some people forget is that if you print a lot of one of
the colors of ink in a cartridge, it may well run out of one color,
rendering it pretty nearly useless, long before the other colors are
out. I have to remind my wife NOT to keep using yellow backgrounds on
all her greeting cards.
> for the Epson.
> Art
This is evidently not true for the carts I use as I often stock up on
them at Sam's Wholesale Club so that I always have a new one on hand. I
have never run into the problem you refer to. Maybe that is because I
use cheap printers.... Grin.
