I have an HP v220W 8GB pendrive, it is not being detected in my car stereo system. What to do now. I was using the same pendrive for my car stereo system before also, but now it is not reading, i'm getting an error "USB NOT SUPPORTED".
Then try to format it to FAT32 (Make sure you save your documents to the computer first). After formatting, return the documents to the pen drive and then try it out. If it doesn't work then format it to FAT or exFAT and apply the procedure for the documents.
Thank u very much. I formatted my pendrive to Fat32 format now it is working perfectly
