I own an HP z400 workstation. I want to use a high-end graphics care that requires more power than what the machine comes with. However, it seems that putting a third-party ATX-style power supply into the z400 won't work because HP has some propriety things going on with the power supply.
Check out the first sentence in this z400 data sheet on the HP site: http://www.hp.com/united-states/personal_again/datasheets/the z400_ds.pdf
And the middle of the "Innovation..." paragraph on page 1 of this z400 info document: http://h20195.www2.hp.com/v2/GetPDF.aspx/4AA2-4464EEE.pdf
Also, check out the “HP WattSaver” section at the bottom of this page on an HP "UK" site: http://h41111.www4.hp.com/new_workstations/uk/en/profinno_environment.html
And you can see the phrase “Power Supply – 475 watt custom power supply - (Wide Ranging Active PFC)” if you search for the word “Custom” on this Russian HP z400 info site: http://www.server-unit.ru/tekhopisaniya/workstations/hp-z400-workstation
One thread on another forum suggests that a home-made wiring adapter that rewires the connections for the system-board power plug can do the trick: http://forum.corsair.com/forums/showthread.php?p=457289#post409472
So, my questions, please, are:
Is there any chance we're losing something important with this wiring adapter in terms of the "custom" power features of the z400?
Or are we pretty sure it will work just the same as the supplied power supply?
And if we're sure it will be okay, any chance I can please get a more explicit and/or updated explanation of how to make the adapter and what it's doing, so my tech guy can take it from there?
Thanks a million!
Jay
Thanks a million!
Jay
