footbrake4life :
Also the unit is not using an HP "approved" GPU or RAM. The current config on the unit in question is a EVGA GTX 760 with 16GB of crucial 1600 ram
footbrake4life,
I have two z420's and the fan actions on both seems odd sometimes. When starting these systems, sometimes the fans roar at full speed for about 8 seconds or so and then settle back to being very quiet. This happens more often when restarting, but that makes sense because the system temperature sensor is still reading as hot. Other times, the systems will start at the lower speed.
Here]'s a possiblity: install a system monitor that displays CPU, GPU temperatures and also the fans speeds. My thinking here is that the CPU or GPU temperature sensor is the faulty part- not the PSU- and it's constantly telling the system that the CPU is overheating. If you see very high temperatures when the system is first started from cold, that would indicate this problem.
Cheers,
BambiBoom
HP z420 (2015) > Xeon E5-1660 v2 six-core @ 3.7 /4.0GHz > 16GB DDR3 ECC 1866 RAM > Quadro K2200 (4GB) > Intel 730 480GB > Western Digital Black WD1003FZEX 1TB> M-Audio 192 sound card > Logitech z2300 > Linksys AE3000 USB WiFi > 2X Dell Ultrasharp U2715H (2560 X 1440) > Windows 7 Professional 64 >
[ Passmark Rating = 4918 > CPU= 13941 / 2D= 823 / 3D=3464 / Mem= 2669 / Disk= 4764]
Pending upgrade: HP /LSI 9212-4i PCIe SAS /SATA HBA RAID controller, 2X Seagate Constellation ES.3 1TB (RAID 1)
HP z420 (2013)(Revision 2) > Xeon E5-1620 four core @ 3.6 /3.8GHz > 24GB DDR3 ECC 1600 RAM > Quadro 4000(2GB) > Samsung 840 (250GB) WD Black 1TB > > M-Audio 192 soundcard > Linksys WMP600N WiFi
[Passmark system rating = 3815 / CPU = 8985/ 2D= 767 / 3D= 2044/ Mem= 2523 / Disk= 2986]
