Question HP z420 workstation memory help?
Jun 8, 2019
11
Hi i have a HP z420 workstation with an e5-1620 processor and 8 dimm slots i just bought 2x16gb sticks of ram and need 2 know what dimm slots 2 put them in they are by themselves plz help
If you go to HP and view the online owners manual you can get that info. But that's actually a 4 channel RAM system. You should get 2 more matching sticks. 4x4GB would be a correct 16GB setup.
when i got the computer it had 1x2gb stick in dimm slot 8 and it worked and supposedly the 2gb should have been in dimm slot 1 not 8 so im confused
You will be losing performance if you make it run anything other than a 4 channel setup. Running a 6 core CPU with 12 thread cabability on 2GB may run, but you can't say it actually "WORKS". If you look at the configurations HP offered which should be shown in their manual then you will have something that will perform properly. The memory controller may or may not split those 2 modules into 4 channels for you. It may depend on which 2 slots they're in. This will depend on how the slots were configured by HP.
http://h20195.www2.hp.com/v2/getpdf.aspx/4aa3-9557enw.pdf
ok ty i hope it works... atleast it will be better then 2 gb ram
so even though the mb says i have the 2 gb stick in slot 8 and online it says 1 stick should be in slot 1 the motherboard is probably printed wrong?
They probably just stuck a module in to show that it can boot. It's not uncommon for a "barebones" system to come without everything actually required to function properly. It's also not uncommon for computers to suppport larger modules than were offered originally. They double in size very couple years.
Memory needs to rest every few cycles to refresh. Multiple memory channels allow the RAM to keep working while other modules are "refreshing". Faster multicore CPUs need more channels to support their speed, and bandwidth.
Dual channel memory was last used in a workstaion on 4core 4 thread systems in the LGA775 era.
I'm not saying it doesn't work. Runs just fine in my $20 Optiplex 380.
Reactions: LoLLess
ok cool so basically just buy 2 more sticks and it should be fine and stable? yea i only paid $50 for this 1 well worth imo
When you get the new sticks, make sure that they match your existing sticks in EVERY specification. Getting un-matched ram to work together is problematical at best and impossible at worst. Sometimes, even the EXACT same brand, make,and model will not work together, especially if purchased at different times and vendors. Even the ram manufacturer will not support unmatched ram to work. They sell ram in matched sets for a reason.
