hp z600 mobo in normal ATX CASE
I'm not familiar with the z600 but I just note the wire coloring at the switch, at worst you just follow the wires down to the connector.
Solid White is often the common or ground wire that all the switches will use.
Repeating this for USB can be done but you will need to know what you are doing to tell which wire is which pin if HP didn't use standard wiring there too.
Assuming you are using a standard psu you need the Z800 Z600 PSU Main Power 24-Pin to 18+10-Pin Adapter to convert the proprietary HP connection
https://www.moddiy.com/products/HP-Z800-Z600-PSU-Main-Power-24%252dPin-to-18%252b10%252dPin-Adapter-Cable-(30cm).html
Unless you have a z600 case/psu I would suggest you sell the z600 and start with a Supermicro X8DTi-F (1 x pci x16) or X8DAI if want on-board audio or the X8DTG-QF if you want 4 pci-x16 slots and an "unsupported" quad sli gpu monster.
Here's my "i5-6400 build" that morphed into a X8DTi-F Dual x5680, 48gb ddr3, 240gb pci-ssd, gtx 760 beast
http://www.tomshardware.co.uk/answers/id-3122260/6400-cpu-mobo-8gb-ddr4-cheap-236.html
http://www.tomshardware.co.uk/forum/id-3145316/cheap-server-parts-dual-xeon-x5680-battleship-build-pocket.html
Before upgrading the x5650 95w air-cooled to my current x5680 135w water-cooled setup..
For $250 (upgraded cpu's $150 x5680, $200+ x5690)
Supermicro X8DTG-QF, 48GB DDR3, 2x Xeon 5530 CPU, 2x CPU Coolers
$100 Aluminum Open Air Mining Case 4 LED Fans For 6 GPU
http://www.ebay.com/itm/Aluminum-Open-Air-Mining-Miner-Frame-Case-4-LED-Fans-For-6-GPU-Crypto-ETH-ZCash-/372027910277?epid=16006054921&hash=item569e976885:g:FMsAAOSwvT5Ze-1j
$150+Two (2) Gigabyte WindForce 3X GTX 780 3GB GDDR-5
http://www.ebay.com/itm/Two-2-Gigabyte-WindForce-3X-GTX-780-3GB-GDDR-5-Video-Cards-SLI-Setup-/182701049143?hash=item2a89d4c537:g:zXIAAOSwx2VZg8qe
That's $650ish, which is good, cause the more $$ than sense rig is a bit pricey (it probably wouldn't work but it would be fun to find out)
Lot of 4 Gigabyte GeForce GTX 1070 8G Video Cards $2000
http://www.ebay.com/itm/Lot-of-4-Gigabyte-GeForce-GTX-1070-8G-Video-Cards-/132275634242?hash=item1ecc3e0042:g:HTIAAOSwuaFZehN3
And when everyone claims you can't watercool Supermicro server mobo's, or any server mobo (the party line is to water cooling is "not compatible") Nope, it's a pretty cheap & simple work around, and if this doesn't convince you that water cooled servers are real..
