[SOLVED] HT Omega Claro Control Panel Issue
ikeptthefaith
5
Hi guys! I have an HT Omega Claro II sound card that won't switch audio channels anymore. When I try to select a channel other than 2, it freezes and when I select S/PDIF In Loopback under my S/PDIF Output, my whole rig restarts. What's going on?
Lutfij
What OS are you working with? Make and model of your motherboard to which the sound card is plugged in to? Might want to see which BIOS version your motherboard is on. If you have any BIOS updates pending, gradually work your way to the latest.
Lutfij
ikeptthefaith
5
Thanks! Win10, MSI 350 Tomahawk ver. 1.5.
This worked. I updated all of the motherboard drivers (they were ancient!) and I can now switch audio channels.
