HTPC and Emulator PC Help
PCPartPicker part list: http://pcpartpicker.com/p/C74yyc
Price breakdown by merchant: http://pcpartpicker.com/p/C74yyc/by_merchant/
CPU: AMD A6-5400K 3.6GHz Dual-Core Processor ($39.27 @ NCIX US)
Motherboard: ASRock FM2A78M-ITX+ Mini ITX FM2+ Motherboard ($77.98 @ Newegg)
Memory: Team Elite 4GB (1 x 4GB) DDR3-1600 Memory ($31.99 @ Newegg)
Storage: Intel 520 Series Cherryville 120GB 2.5" Solid State Drive ($49.99 @ NCIX US)
Case: Cooler Master HAF Stacker 915F Mini ITX Tower Case ($29.99 @ Newegg)
Power Supply: Corsair CX 430W 80+ Bronze Certified Semi-Modular ATX Power Supply ($29.99 @ Newegg)
Total: $259.21
Generated by PCPartPicker 2014-12-13 16:12 EST-0500
For emulators really (N64, NES, Gameboy, PS1/2, Gamecube). Ill be playing it on a 1080p 32 inch TV. Will this be a good build? Budget is around $250.
Thanks!
Emulators can be very heavy on CPU actually (especially Dolphin or PS2).
But for your budget it has hard to do better, especially if you want an SSD.
I am not too familiar with AMD builds, maybe you can find a cheaper mobo (although ITX is expensive).
The motherboard will have 0 effect on performance, all you want is specific features and reliability.
