Hi All,
I'd like to build an HTPC that allows me to cut the cord to cable and add an antennae. The factor that over-rides all other considerations is that my TV can only take component analog inputs (ypbpr) and I don't have the budget for a new TV along with the system. Also has to be easy for my wife to use.
My goals are: DVR software, don't need to record more than one show at once, but it would be nice to watch one show while recording another, BluRay playback, playing files off of my laptop that I have connected to network (laptop is wireless, HTPC would be ethernet).
Approximate Purchase Date: e.g.: December 2013
Budget Range: (e.g.: 300-400) $500 to $700 after shipping, rebates, and including OS
System Usage from Most to Least Important: Live and Recorded TV, website playback (like NBC.com or Youtube or Netflix, file playback, BluRay, very light gaming.
Are you buying a monitor: No. The TV I have is a Phillips HD tube TV that looks great still and weighs about 300 lbs. I literally can not move it anytime soon.
Need a complete system, I have no existing parts except for the TV and the sound system.
Do you need to buy OS: Yes, would consider linux, but have never used it.
Preferred Website(s) for Parts: NewEgg
Parts Preferences: None
Overclocking: Maybe if needed.
SLI or Crossfire: Maybe if needed
Your Monitor Resolution: TV will accept 480i, 480p, 720p and 1080i through the component inputs/
Audio: I have a sound system that can take optical audio inputs.
And Most Importantly, Why Are You Upgrading: Want to stop paying for cable
I like this build from the recent poll but need a Tuner Card and a GPU that has D-Sub out that I can convert to Component with an adapter cable.
A little bit of blu-ray, a little bit of couch gaming.
CPU: Intel Core i3-3220 3.3GHz Dual-Core ProcessorP ($118.99 @ Amazon)
Motherboard: Gigabyte GA-H77M-D3H Micro ATX LGA1155 MotherboardP ($88.24 @ Amazon)
Memory: Wintec AMPX 8GB (2 x 4GB) DDR3-1600 MemoryP ($59.99 @ Newegg)
Storage: A-Data Premier Pro SP900 64GB 2.5" Solid State DiskP ($69.99 @ Amazon)
Storage: Western Digital WD Green 2TB 3.5" 5400RPM Internal Hard DriveP ($93.91 @ Amazon)
Case: Silverstone ML03B HTPC CaseP ($59.99 @ Amazon)
Power Supply: SeaSonic 360W 80 PLUS Gold Certified ATX12V Power SupplyP ($59.99 @ Amazon)
Optical Drive: LG UH12NS30 Blu-Ray Reader, DVD/CD WriterP ($39.99 @ Newegg)
Video Card: Sapphire Radeon HD 7750 Low Profile 1GB DDR5 ($104.99 @ Amazon)
Total: $696.08
Total: $696.08
