HTPC Build Need Help - Audio
tweak13
139
Well my idea is to make a neat little htpc with a blu-ray player for my girlfriend. The biggest thing I don't really understand is what audio options I have with an htpc (never built one). Should the sound transfer over the hdmi link from the mobo to the tv or would I have to use SPIDF from the mobo to a receiver?
I'm looking at getting this board, which has integrated HDMI and SPIDF.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813500029
Doing sound through HDMI would rock, she really would like sound to just come through the tv to keep it simple, and of course not having to go buy a speaker system with a receiver that has SPIDF would keep some money in my pocket.
There are HTPC motherboards with HDMI outputs and onboard gfx. The best of these for gfx are the 780g and even better 790g AMD chipsets
Presumably they can just run the onboard sound through the HDMI as well . The place to start would be on the mb makers website
I just had a look at gigabytes website
http://www.gigabyte.com.tw/Products/Motherboard/Products_List.aspx?VenderType=AMD&CPUType=socket+am2%2b
and then randomly picked a 780 g board
http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=2932
Im picking that reading some of the online manuals will clear up a few issues for you
Yea i actually just read an article on that also, I think i'm going to wait for that board for sure since it has the built-in wi-fi adapter also, that little board is pretty killer.
