Huawei Compatible USB Modem For Rogers LTE (Canada)
audiotek
77
Anybody here would know what Huawei stick would work with Rogers LTE in Canada? Rogers stopped providing the Sierra AirCard 330u and decided to replace it with a hotspot modem. I need the stick for a spare and that hotspot thing wont work for me.
I found that the Huawei e397b is compatible but I cannot find the right model that fits Rogers frequencies or any place where they would sell it!!!
Thanks
Hello,
Are you sure Rogers stop providing sale and support to Rocket Sticks Sierra.. I found link say they are still sale it:
https://www.rogers.com/web/content/LTE-RocketStick-Ottawa?cm_sp=Consumer-_-Wireless_0608_Eng-_-LTE_OTTAWA_HOM_PRE_slot1
However, you probably can use Huawei e397b with Rogers SIM card if that Stick unlocked to any network
but lately I know all that Turbo Sticks are locked and not uncheckable
My suggestion to confirm if Huawei e397b can work with Rogers SIM or other provider SIM card
Best of Luck
That's cool. I heard they put them back on the market but wasn't to sure. I find the 330u a bit big so I'd like to e397. From what I red the the e397 doesn't support 2600Mhz
Any stick will be unlocked if you buy it outright with your own money and DO NOT allow them to put you on a plan to purchase it on a contract.Then you can just put your SIM card in it and use it on Rogers.
9vTRNE
