Hi guys i've recently noticed that i do a lot less fps than my gpu is capable of and even a friend of mine with a 2060 can do more than me , i've done everything to optimize the pc but nothing changed
OS: windows 10
CPU: i7 8700 (non k) (4.28 GHz, 6 Cores, 1 physical processor ,12 logic processors)
GPU: RTX 2080 OC ( 8GB VRAM) (lastest drivers)
RAM: 16GB single channel (2400Mhz)
SSD: ADATA SU630 500GB (with OS in it)
HHD: TOSHIBA HDWD110 1TB
PSU: Enermax Max Pro 2 600W
Motherboard: Msi H310M PRO-VD PLUS
PROBLEM1: Low GPU and CPU utilization in most newer games
PROBLEM2: Lagging a lot when downloading something on an external launcher: steam, origin , qbittorrent (slow browser opening, slow pc in general)
PROBLEM3: Getting LOW (60-80) FPS in games with bigger maps (Fortnite,Warzone,Battlefield, final fantasy, GTAV, FarCry 5-NewDawn)
( Note: Changing graphics settings doesn't lower/raise fps
( Note: Even the resolution doesn't matter
( Note: In normal sized maps the problem does not occur
Here are two images (two different games)
POSSIBLE SOLUTIONS:
1. CPU bottleneck
2.Bad Motherboard
3.RAM bottleneck
i need help to find the real problem before spendin 600$ on new hardware , so pls tell me what's the problem
OS: windows 10
POSSIBLE SOLUTIONS:
1. CPU bottleneck
2.Bad Motherboard
3.RAM bottleneck
