Okay so I'll skip the story and explain what happened. So some water was spilt onto my computer and went through the top of my case and the fan flew it all inside on the hardware. Immediate blue screen and wouldn't turn back on. I unplugged the computer and took a blow dryer to It on low for around half an hour and tried to turn on. I booted it back up and it went to the bios and booted up about 95% of the way. It then turned off. I unplugged it and tried to let it dry out for around 2 hours. I then tried to turn it on again. It booted for around 2 seconds and it sounded like the disc drive/HDD made an odd scratching noise. I tried to turn it on about 5 more times and the noise stopped but it only boots for about two seconds then shuts off and loops repeatedly, on for 2 seconds off, off and on. I opened the case and tried to see what was working.
all fans are running and GPU fans are running as well. (Hoping GPU/CPU aren't an issue).
My guess so far since everything seems to be working is
1. power supply is messed up
2. Motherboard is fried.
If you can confirm it's either of those two parts I'd greatly appreciate it.
EDIT: Note. Water was on my PSU, MOBO and a little drip on my GPU (I assume that's fine, if not I have a temporary replacement.).
Sorry for any grammar mistakes as I'm writing this on my phone since I'm without a computer 🙁
