I recently built a new PC and there's a humming/buzzing noise from the speakers connected to the onboard audio jack. It sounds like when you're touching the 3.5mm audio jack from the speakers, but much, much quieter. The noise is quite faint but loud enough to annoy me. It doesn't change if I increase the volume via software, but it does gets louder if I increase the volume with the volume knob on the speakers. (So not OS related?)
The noise stops when I'm playing audio. When I stop playing audio, everything is ok for a few seconds and then the noise is back. (My uneducated guess would be that the audio chip is going to sleep, leaving the speakers with no signal, so the pick up faint garbage from somewhere. Does that make sense?)
I'm using a 3.5mm audio jack splitter to send audio to my PC speakers and my stereo. If I remove the splitter and only plug in the speakers or stereo, the noise goes away. So obviously the splitter is the cause, right? Well, no, because this same setup (same splitter, same speakers, same stereo) has been working flawlessly for many years with my previous PC.
I'm wondering if this is related to the motherboard not being grounded? The motherboard doesn't seem to have a GND pin, or at least it's not labeled. On top of that, the case doesn't seem to have a ground connection either. Is this normal for modern PCs?
Here's the pin layout for the front connectors from the motherboard manual:
I don't think this is OS related, but I'm running Linux, so there are no drivers I could reinstall.
I've updated to the latest (non-beta) UEFI with no success.
Any help would be much appreciated.
CPU: AMD 5600G
CPU cooler: Alpenföhn Ben Nevis Advanced
Motherboard: ASRock A520M Pro4
Ram: Corsair DIMM 16 GB DDR43200 (2x 8 GB) Dual-Kit
SSD/HDD: Crucial P3 SSD 500 GB, M.2 NVMe
GPU: None
PSU: be quiet! Pure Power 12M 550W
Chassis: Fractal Design Define 7
OS: Debian testing
Monitor: Iiyama ProLite XB3270QS-B5
CPU: AMD 5600G
GPU: None
OS: Debian testing
