HW Monitor showing high max temp at startup
mhokett
112
HW monitor is showing a max temp for CPUTIN and AUXTIN approximately 34C higher than actual when i start HWMonitor. I have tried clearing min/max and uninstalling/reinstalling it, but the problem remains. Any suggestions would be helpful.
MB ASROCK M3A770DE
CPU Athlon II x3 455 unlocked to Phenom IIx4 B55
The temps in bios match the actual temps fine. The problem is that the software is immediately showing a max temp for these two fields at 34C higher when the program is started. They also increase as the actual temps rise. So basically it is adding 34C to the max temp. tried realtemp, but it will not run as it doesn't recognize my unlocked processor.
