HydraLux-4 is First Liquid Cooled LED Lightbulb
What we really should care is the comparison to a CFL. Accroding to Wikipedia, CFLs use 1/3rd to 1/5th of the energy of comparable incandescent bulbs, so we are roughly speaking 6-8 watts CFL is comparable to a 4W LED light bulb. Not so impressive, but still an improvement. At least until we get to the sticker shock. Since I've been using CFLs at home exclusively for years, it doesn't make much sense to upgrade to LED. Perhaps in a few years when the long lived CFLs start to die, or perhaps a decade until I run out of the spares I already have as well...
In general i think they should at least be shaped like the bulbs they are replacing. Many people are so use to what a A19(normal bulb) looks like that they do not tend to like these new ones.
It will be nice to see a 25 watt equiv though. 40 is just too much in my fan.
I would get a couple if the prices came down. The one thing that annoys me about CFLs is that it takes a few seconds (sometimes more) to warm up (reach full brightness)... also no mercury is a plus
well it's less than i figured it would be (i figured close to/over $50) and an led light would last for one heck of a long time, but i never figured an led light would get hot enough to use liquid cooling
Unfortunately all of the LED lights are low wattage, if they can give me something equivalent to a 40 or 60 watt incandescent then it will be useful, but a 25 watt incandescent just isnt enough to light a room.
[citation][nom]hunter315[/nom]Unfortunately all of the LED lights are low wattage, if they can give me something equivalent to a 40 or 60 watt incandescent then it will be useful, but a 25 watt incandescent just isnt enough to light a room.[/citation]
read the article.
Eternaleds plans to announce 8W, 12W and 16W versions of the HydraLux by the end of 2009.
@hunter35:
GeoBulb® LED Light Bulb (Cool White)
"It puts out more light than a standard 60-watt bulb but uses less than 8 watts. LED bulbs last 3 years of continuous use or 10 years at about 8 hours per day."
Sounds good to you?..😉
It is cool if I have extra $99.95 to spend on a light bulb....>_<
http://www.ccrane.com/lights/led-light-bulbs/geobulb-led-light-bulb.aspx
hmm.... something off topic... something funny...
I can't make any post or reply (while login and can + or - posts..) with either IE8 or firefox.. only my Safari 4 works...
hmm.... not sure what happen.... must not be kind of Apple-TH things...lol.....
It must be some kind of setting problem...
i don't have a thing for high power/cooled LEDs, they are supposed to be efficient like the low power LEDs commonly used.
will wait for OLEDs for household lighting.
Philips has the Master LED lights, but they are only available in Europe as they using 230 volts. First saw these online sometime last year.
Nice, but still missing replacement for my 50W Hallogen MR20 flood bulb. These get extremely hot and being receded, it kind hitch me with the risk of fire. LED lightning would greatly reduce dissipated heat AND save me lots of cash (15x50 = 750W).
I haven't noticed that any LED needed cooling. Perhaps some high wattage industrial app but you don't see cooled LEDs at homedepot and such. 4 watts can't possibly burn down your desktop lamp right?
It may be the transformer that step the power down, but even then, i find it hard to see that much heat. Since everyone is doing it, there is a reason, or they are just trying to make it look better like some motherboards have cooling that is not needed at all.
I've seen the website pictures, and it's clear that the daylight white (the first bright white on the video) is about equal to a 25W lightbulb.
The 'Warm White' gives off considerably less light, and is more comparable to a 20W lightbulb.
"it's clear that the daylight white..."
Yes, it's one of the things I don't care about "white" LED lighting. Fine for flashlights, but awfully "cold" for work, and even worse for most "home" environments. I'd rather have a "warmer" 20W-equivalent bulb than a "colder" 25W-equivalent bulb.
I'm surprised that refrigerator manufacturers haven't jumped on the LED bandwagon. Imagine having lighting on EACH level in a fridge, lighting the back as well as the front, lighting in the vegetable bins, etc. And all for less than the 25 - 50 watts normally consumed by the incandescents usually used. (I've replace the incandescents with tiny CFLs in mine - more light, more efficient - less power used & less heat generated.)
Still, the long-life and no mercury surely beats the twisty-tube CFLs. I also agree that they need to re-design the product so it fits the same space as a standard incandescent bulb.
The key thing is longevity. That was promised by CFLs but not delivered as far as I'm concerned. I'm always replacing the damn things. Not to mention you can't just throw 'em in the trash because of the mercury.
These expensive bulbs are only useful for applications where they are on all the time. I mean 8 hours of run time per day? During the summer most of our bulbs are hardly on at all except a few hours at night. Daily usage is important as it moves out the break-even point.
Not to mention that the break even point lies so far away that by the time you're half way there there's probably a cheaper alternative available. Sort of the same reason we shouldn't both building star ships now. They will be 10% of the way there when they get passed by a faster ship launched 40 years later :)
The big question I have is are they dim-able? Most LED replacement lights are not dimmable, and when they are they're very expensive. Hoverer most CCFL are not dimmable either.
As for the cooling a >2W LED need some form of heat sink as the chips are very small like 1mm^2 and most of the 4W is heat(~3W) not light(1W). A good LED is ~25% efficient (usable light per Watt) Not much different then PC chips needing heat sinks, except that the LED chip has much smaller surface area to dissipate the heat. The voltage transformer/regulator is also another likely suspect for heat as LED use 1.2VDC - 3VDC for normal operation. LED are current controlled devices, after all they are nothing but a special type of diode.
The main cost effectiveness of LED bulb is the lifetime, and not needing to replace them often. Very important if the light fixture is hard to reach, like a convention hall, lobby, or conference room ceiling.
