• Now's your chance win big! Join our community and get entered to win a RTX 2060 GPU, plus more! Join here.
    Meet Stan Dmitriev of SurrogateTV on the Pi Cast TODAY! The show is live August 11th at 2:30 pm ET (7:30 PM BST). Watch live right here!
    Professional PC modder Mike Petereyns joins Scharon on the Tom's Hardware Show live on Thursday, August 13th at 3:00 pm ET (8:00 PM BST). Click here!
[SOLVED] Hydro and larger RGB 200mm fans
Jul 8, 2019
96
4
45
I'm not exactly looking for private information, but if I decided to have three 200mm fans with RGB lights on them running 12 hours a day, would my hydro bill be significantly higher than a few 120mm fans with no lights? I am working on a new build and would like everything to be perfect.
Computer fans don't use much power. I couldn't imagine it making much difference. Most fans are going to be about 3W to 4W under load. The heavy duty 140mm Noctua Industrial iPPC draws about 6W under load at 3,000RPM.
I doubt those 200mm fans are getting anywhere close to 3,000 RPM. I'd expect them to maybe draw 5W to 6W at full load each. Even that is probably high. LED accent lights power usage is virtually non-existent. Perhaps you can find their spec page. Which will hopefully list their AMP or Watt rating.
