G
Guest
Guest
Hi,
I have a question. I added a Pull fan to my Hyper 212+ and now temps seem to be hotter by two degrees and jump around a lot. Before I added the pull I had temps around 33 degrees to 35 with my heat off. Sometimes temps would be up to 37 or so with the heat on in the apartment. Now temps are 35 -36 without the heat on and my screen door is even vented at this moment, so it is not hot in here at all.
I have hooked the fan which is a cooler master blue led 2000rpm to a open spot on my motherboard for a fan. Should I use the connector that came with the fan and directly wire it to the power supply? Maybe the fan is not turning fast enough? Or Would it be possible I have the connector backwards on the board connection causing backwards rotation, I doubt this theory but thought I would throw that one out.
I am 100% sure I have the air flow direction aligned properly for the fan. I looked on it before even putting the clips on it and I did buy two of these fans and the other is a case fan replacement. Which the one on the case is an intake properly flowing. I looked at the stickers while in the case and both fans are aligned properly for their job.
Any suggestions?
Or ideas?
Thanks for help
Any suggestions?
Or ideas?
Thanks for help
