[SOLVED] Hyper 212 bracket problem + picture
If your kit didn't come with ALL of the following, then you are missing parts. And clearly there are two different styles of cross brackets. What socket design is your motherboard?
Yes. Either you are not using the correct mounting hardware backplate and standoff screws, which will change the height and bork the whole installation, or you haven't screwed in the other side enough to keep it from coming loose. Or, it may be related to the center screw.
it only came with one blackplate and standoff screws i couldnt have messed that up
centered screw?
how come everyone has X bracket and they only gave me
