Hello guys,
Does anyone know what stock fan the CM Hyper 212 Evo uses? I warnt to add an additional fan in push/pull to lower my temps by a few degrees but have OCD with this kind of thing so will need another identical fan 😛
Does anyone know the fan model? Or of any better fans I could use?
Thanks,
Conor
Hi Conor,
Well the fan in question is called: Blade Master 120mm
(R4-BMBS-20PK-R0). Although the one used on the Hyper Evo is the smoked or transparent version, but it's the same fan.
I know because I currently use the 212 Evo and I looked at buying a second CM fan for mine. The problem is, like me, you're from the UK, and well I tried "everywhere" to get one of these fans but I couldn't find them anywhere. The only place I could find them was on sites in the US which isn't really a viable option as the postage would be 5 times the price of the fan!
In the end I went with 2 of
Corsair's SP120 High Pressure PWM, they look great and I would say they are slightly quieter as well. But to be honest the only improvement was the look, my temps didn't drop at all, nothing noticeable I'm afraid. And I tried reseating the cooler about half dozen times, trying different TIM's (Thermal Pastes) and different ways of applying it, but still no improvement, except the cool look =)
Hope this helps, and hey if you decide to go for it and you manage to get one I hope you have better luck than me mate
