Hi, so I just bought this new PC it's working very nicely, but I'm just not sure if these calculations are normal. So HWmonitor says that my 212 EVO is running at 1900 RPM and this is just on idle. Even when I change it to power saver it still stays 1900 rpm.
Now for the CPU, I have the I5 2500 (non k). It runs very cool (constant 1900 RPM) around 24-29 C on idle, but a constant 3.7 GHZ which should be the turbo ( this happens on high performance), but when I put it on power saver/balanced mode, it drops to normal 1600 MHZ idle, but even then my 212 is at 1900 RPM.
Please let me know if these speeds are normal, thank you!
EDIT: It's actually the Hyper 212 EVO +, if that changes anything.
