Hyper 212 Evo Fan Compatibility
Scaream
11
Hi, I am in the process of picking parts for a gaming pc and am looking for a case that is compatible with the Hyper 212 Evo from Cooler Master. Pcpartpicker.com seems to have a problem to justify whether a case can house the fan. I am also looking at a case that can house the AMD FX-6350 CPU & the GTX 960 CPU
I am looking for someone to suggest a case preferable mid-tower
Thanks
If you have a 60 case budget, I'd go with this case. Good quality, supports up to 160mm coolers (The 212 EVO is 159mm, again, the Cryorig H7 is a better choice if it's available in your country) and has pretty decent features including a windowed side panel.
Case: NZXT Source 210 Window ATX Mid Tower Case ($52.98 @ Newegg)
Total: $52.98
Generated by PCPartPicker 2015-05-31 14:35 EDT-0400
I'm not sure how a 50 dollar case can suppress your budget on a 60 limit, unless you're in a different country where the prices are much different.
This case has decent quality and fits the EVO.
Case: NZXT Source 220 ATX Mid Tower Case ($49.99 @ Micro Center)
Total: $49.99
Generated by PCPartPicker 2015-05-31 12:20 EDT-0400
But honestly, this is a much better cooler in consideration of performance, ease of mounting, sound levels and RAM clearance, plus, it's shorter and so can be used with a larger variety of cases.:
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler ($34.50 @ Newegg)
Total: $34.50
Generated by PCPartPicker 2015-05-31 12:21 EDT-0400
There are certainly better cases as well. It just depends on what you want to spend and where your tastes/desires run in regard to aesthetics.
Is the 212 Evo really much bigger, because I am looking at the Enermax ECA3290A-G and it has good customer reviews, just little worried if the 212 Evo will fit because both the Cryorig and the NZXT case both surpress my budget a little bit (if you were wondering my budget for a case was $60 or less)
Total: $52.98
