austin.weimer :
So my hyper 212 evo the x mounting bracket connects to all the mounts until I put the cooler master down and put the x bracket in and then the screws will align but won't reach far enough to hit the mounting screws and if I get one side down I can't get the opposite side down
I had the same issue, sounds a bit whiney but make sure u follow the steps CORRECTLY on the manual, each sockets has a diffrent X angle.
Tho you are saying the screws don't reach the sockets. The screws got springs around it so u have to force it a bit, not to much. And make sure u do them in the right order. As showed on the manual.
