Hyper 212 evo temps too high with 6700k under 100% load(?)
Awesomness03
15
I put my cpu under 100% load for about a minute or 2 and the temps jumped to 85 max and that seemed a little too high from everything I've read on this site. I just reinstalled yesterday triple checked the amount of thermal paste, the tightening of the mounts, and the cable management. I have 5 case fans with the In win 303 case: 1 exhaust right behind the cpu heatsink, one exhaust right below the gpu, one intake on the left edge bottom of the gpu, and two intake fans at the top.
Update: So I tried the 2 exhaust top and 2 intake bottom + 1 exhaust in back, and although it's working a little better, temps are still reaching upwards of 82 with 100% load.
I used the little dot in the center method and as for clamping pressure I just tightened the screws fully until they wouldn't turn more.
I did tighten the nut and I'll try changing the fans thanks.
