One of the fans on my Hyper N620 is making a really annoying 'tapping' noise. If I put a little pressure on the middle of the fan, the noise stops. I don't really know what to do with this thing.
As you can see from this pic http://www.hardwaresecrets.com/fullimage.php?image=21231 it only has 2 screws per side at the top, so it doesn't really give me much to work with anyway. I've tightened the screws on the 'chattery' side to no avail.
Any suggestions other than replacing it?
