Hyper TX3 plus Fan installation issue
Bahazbz
111
Here's a "fun" question. Is it normal to need to apply EXTREME force to pull down the lever on the Cooler master Hyper TX3 plus cooling fan when installing it on an AM3+ socket. I have been fiddling with it for days now, and I want to get this thing attached. I am fairly certain I have all the mechanical peices I was provided by cooler master in properly, but the final securing lever that needs to lock all the way down seems to only go 40-70% of the way down no matter how hard I press. IT always springs back afterward leaving the fan loose and precarious over the CPU socket.
I am afraid to apply any more force as the board flexes considerable every time I pull the lever across, and I don't want to leave the lever open, (or else the heavy fan could fall onto my graphics card as it is only being held on by thermal paste right now.)
What should I do? Return the fan and get another? Attempt to force it and risk irreversible damage? Or leave it unattached and risk the falling hazard?
I'm getting pretty frustrated as nobody else seems to be having this issue... PLEASE HELP
This is my first rig.
I have a TA970 board, with an FX-8320 already installed.
Whatever you do, when you're ready for the final installation, DO NOT use more than an amount equal to a very small snow pea or uncooked rice grain sized amount in the center of the unit. Every video or photo tutorial I've seen related to that cooler shows GOBS of it being used, which is very, very wrong. I realize you probably know better than to do that, but it never hurts to emphasize it.
A few more hopefully helpful links:
http://www.hardwaresecrets.com/article/Cooler-Master-Hyper-TX3-CPU-Cooler-Review/848/4
http://www.overclock.net/t/1185304/cooler-master-hyper-tx3-review-for-amd-owners
Well, honestly the video I showed you here: https://www.youtube.com/watch?v=xYyqe4N1ZT4 is pretty much self explanatory, but if you're having issues I'd suggest that perhaps the articulation of the lever arm isn't oriented correctly or something isn't sitting quite right. If you're trying to do it IN the case, I'd suggest maybe taking it out of the case and practicing with securing it without any thermal paste until you've got it figured, then do a final run using the thermal paste. It does get tight, but it shouldn't get SO tight that it feels like it might break.
You might also slightly loosen the four screws holding the backplate brackets to the board, attach the cooler and then retighten the brackets. Be careful doing this though as you could overly tighten the cooler and damage either the board or the cpu. Honestly, it shouldn't really be difficult. I'm not sure how else to explain as it's really exactly like the stock cooler.
Hmm... okay thanks for the quick answer. I thought about the screw thing but was unsure of the possible risks involved in that (again this is my first build). I'll keep trying and ask again if its still an issue in a couple of days.I'm still doing all this outside the case btw. Don't think I had the arm in the wrong way as it won't even come close to the tabs that need to go thought the square holes in any other way, but I appreciate you effort anyhow, thanks!
Make sure you're not trying to use the AMD AND Intel mounting hardware TOGETHER. There should be different mounting hardware depending on which platform you're using. Read the manual that comes with the unit very carefully as it should outline what gets used with which platform.
No, no I'm not THAT novice. I know I'm using the right kind of setup (Angled bar and securing lever, not four push-in clips). Like I said it gets very close to fitting but frustratingly reverses itself every time.
I should post a pic of the manual, It is truly the most unhelpful manual I've ever seen. It's got four tiny, hard to see picture and no written instructions that are in English. Oh well I guess, I'll take a break from this build for a couple of days. Maybe I'll be able to get this to work when I start back up again. Thank you so much for you continued advice. Cheers for now.
Oh my god, it actually worked. VICTORY! I am eternally grateful for you help darkbreeze! It was the lever part of the retention mechanism, even though I had tried it both ways, it must have been in the wrong way (pulling over back to front in relation to the case, rather than front to back in relation to the case). The lever itself was also slightly bent out of proportion(the angle was too large) causing the distance from the square hole to the holder to be too large. I bent it against the table (gently) and now it connects with the lever locking into place completely with minimal flexing. It did not take much force on the final attempt, and thanks to you, I remembered to use a smaller amount of thermal paste this time. It was that second link that finally helped me out, the one with the picture of the bracket showing the angle it should have been. Mine was at least 125% greater than the proper angle when it arrived so that was the problem that ultimately resulted in this thread. The square hole on my unit was a single hole on both sides, not three hole like in the picture, so it may have been a cheaper knock off lever from china or something as I ordered the fan from amazon and it came in some relatively sketchy packaging. I still stand by the fact that those instructions were atrocious though. 😀
The reason I include so much detail is because I know for a fact someone else has the exact same problem and has been searching for a solution even longer than I have. Don't worry you're not alone! I was lucky enough to be given almost immediate help in this forum by "darkbreeze" within literally minutes, and again I can't thank him enough.
This experience has made me a Tom's Hardware user forever, and I'm glad to see there are still helpful, level minded, and diligent people on the internet.
Now that I got the board in the case, all I need is my power supply( I made a separate post about that), a video card, and to install windows. Whoooo ! Thanks one more time darkbreeze, will remember this forever bro.
Link to other post :http://www.tomshardware.com/answers/id-2620797/good-power-supply-workstation-gaming-build.html
