Hyperx Headset makes a loud static sound when i move my head or mic,
TerribleAtTech
23
So i have the hyperx in white and it worked amazingly but now everytime i turn my head it makes a loud static sound, its horrible and loud, i listened to myself and it was so loud , it didnt do this before so i dont know whats up with it, please help, thank you.
Hi,
One way of testing if it's the headset itself that has the problem. Do try another headset or a speaker and see if you'll get that static sound as well. If not that means it's the headset that has the problem. Since it uses a 3.5mm jack and not a USB connector it will not require a driver that can be a factor of that problem as well.
Please do contact Hyper X if it's still under the factory warranty.
http://www.kingston.com/us/hyperx/support/technical/model=cloud
Could you specify the exact headset? Because if it has microphone looping, that might be the problem. That would make sense why it only makes the noise when you move your head or the microphone.
