[SOLVED] I’m terrible at cables HELP !
Aeacus
Glorious
Herald
That's the thing with fully-wired PSU, you will have headache in cable management since you can't remove excess power cables from PSU, forcing you to hide them inside the PC case. Also, that EVGA unit is low quality PSU and i, personally, would replace it with any Seasonic unit for better build quality and better cable modularity as well.
You may take pics of your case but knowing PC case make and model would help us to better visualize your current situation.
Aeacus
Glorious
Herald
