I am wondering if there are any preferred mounting positions for a h100i. My temps are almost 10-15c higher than they used to be on air with my old 212.
Currently I have one in-take in my case and one fan exhausting (other than the h100i itself).
I also mounted the fans on the radiator on the inner part to push air through it. Should I try to make it a pull instead?
I had my PC running for 24h since the day before yesterday (a mix of full load and idle). My city's temperature was at 19c and I believe my room was around 22-23. My CPU had cores peaking at 95C:
7700k @ 4.8ghz
GTX 1080
ASUS Z270
Case is a Corsair 460x
I have one exhaust in the back, in-take on the top and h100i in the front in a pull-to-exhaust setup. I tried mounting the rad on the top but it doesn't fit properly. Any suggestions as to what to look into?
7700k @ 4.8ghz
GTX 1080
ASUS Z270
