I am building a gaming computer and don't know if everything will work and fit?
CameornRock
9
There are the parts -
Case : Cooler Master HAF 912 Plus USB 2.0 ATX Case
CPU: AMD FX8350 Black Edition 8 Core Processor (4.0/4.2GHz, 8MB Level 3 Cache, 8MB Level 2 Cache
Graphics Card: Sapphire AMD Radeon HD 7950 3GB, GDDR5, PCI Express 3.0
Hard Drive: Western Digital Black - 3.5 inch 1TB Desktop SATA
RAM: Crucial BLS2CP4G3D1609DS1S00CEU Sport 8GB Kit (4GBx2), Ballistix 240-pin DIMM, DDR3 PC3-12800 Memory Module
DVD thing: LG GH24NS90.AUAA50B 24x SATA Bare Internal DVD Rewriter
Power Supply: Corsair Builder Series CXM 500W Modular 80 PLUS Bronze Certified ATX/EPS PSU
Mother Board: ASRock Z75 Pro3 Motherboard (Socket 1155, Intel Z75, DDR3, S-ATA 600, ATX)
That's it all, as you can see I'm not a computer genius, I just want to build a gaming pc (I have never done this before) can someone tell me if they're any parts that would be better for this build like a better mother board etc, the main things I need to know if this pc build will work, if it would fit in the case and if the power supply is powerful enough. Also if you have any tips please share them with me, thanks
- CameronRock
All is good BUT the motherboard and maybe Power supply The mother board is LGA1155 which is Intel and you have an AMD FX8350 wich uses socket AM3+ so you need to find a socket AM3+ motherboard that you like tell it to me and ill tell you if its good :)
The powersupply is good but for future upgrades get the CX600W version of it
Hope i helped
Diazalon
Yes go with the CX600 and try this one
http://goo.gl/e66TM7
http://goo.gl/e66TM7[/quotemsg]
Ok, so my final build cost is £680, do you think this will run bf4? and will i be able to play bf3 on ultra settings with a stable fps?
Latest posts
