I am going to be building my first pc. These are the components:
CPU: Intel - Core i5-8400 2.8 GHz 6-Core Processor
CPU Cooler: Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Motherboard: Gigabyte - Z370P D3 ATX LGA1151 Motherboard
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-2400 Memory
Storage: Samsung - 970 Evo 500 GB M.2-2280 Solid State Drive
Video card: MSI - GeForce GTX 1070 Ti 8 GB DUKE Video Card
Case: Phanteks - ECLIPSE P400S ATX Mid Tower Case
Power Supply: Corsair - TXM Gold 650 W 80+ Gold Certified Semi-Modular ATX Power Supply
I based this build from this: https://www.pcgamer.com/gaming-pc-build-guide/
I am wondering if this build is viable? i would like to run each game at 60fps minimum at 1080p. Can you tell me any major faults with this pc build.
Also another issue is compatibility. I checked pcpartpicker and these are the two compatibility issues with this build:
1. The Phanteks - ECLIPSE P400S ATX Mid Tower Case supports video cards up to 395mm long, but video cards over 280mm may block drive bays. Since the MSI - GeForce GTX 1070 Ti 8 GB DUKE Video Card is 312mm long, some drive bays may not be usable.
2. The motherboard M.2 slot #1 shares bandwidth with a SATA 6.0 Gb/s port. When the M.2 slot is populated, one SATA 6.0 Gb/s port is disabled.
Are these compatibility issues major? Should I change my build? Thank you.
EDIT: Also I never built a pc before. So this whole endeavor with pc building is new to me. I am quite overwhelmed with everything right now
