[SOLVED] I am building PC and need recommendation on motherboard and PSU
Nov 19, 2019
hi guys.
I have decided the following parts for my new PC
CPU - Ryzen 5 - 3600
Ram - https://www.newegg.com/corsair-16gb-288-pin-ddr4-sdram/p/N82E16820233852?Item=N82E16820233852
GPU - GTX 1080
Case - https://www.newegg.com/matte-black-red-nzxt-h-series-h510-atx-mid-tower/p/N82E16811146316?Item=N82E16811146316
These items are fixed.
So for PSU and motherboard, i m having my eyes on the following links
PSU - https://www.newegg.com/seasonic-focus-plus-750-gold-ssr-750fx-750w/p/N82E16817151187?Item=N82E16817151187
Motherboard - https://www.newegg.com/asus-rog-strix-b450-f-gaming/p/N82E16813119140?Item=N82E16813119140
Since i am not a overclocking user, do i really need the expensive board and power?
If its not that important, i need a cheaper board under $100 which is also compatible with the ram listed above.
plz give me a recommendations if you know any.
Also here are some links on ROSEWILL PSU
https://www.newegg.com/rosewill-glacier-series-glacier-850m-850w/p/N82E16817182342?Description=rosewill power&cm_re=rosewill_power-_-17-182-342-_-Product
https://www.newegg.com/rosewill-bronze-series-rbr1000-ms-1000w/p/N82E16817182188?Description=rosewill power&cm_re=rosewill_power-_-17-182-188-_-Product
https://www.newegg.com/rosewill-capstone-series-capstone-750m-750w-at-50-degrees-celsius/p/N82E16817182264?Description=rosewill power&cm_re=rosewill_power-_-17-182-264-_-Product
If i pick one of these rosewill's, i can save up to $50... it looks like seagate's product is pretty legit but i am not sure if it really has a significant advantage over the price.
thank you for reading guys!
Latest posts
